Hoping to upgrade
Re: Hoping to upgrade
Hi Tom,
Here is a link to a laptop on PC World to give you and idea regarding the sort of specifications you would be looking at:
http://www.pcworld.co.uk/martprd/sto...ory_oid=-27749haggle.
Brian
Thanks to everyone.
At the moment I am considering that my system may well only need a RAM upgrade, maybe to a GB or two.
I know Stephen uses a laptop a lot for his work and I am wondering if he had any advice on the laptop front.
what is the spec of your laptop?Originally posted by Tom View PostThanks to everyone.
www.crucial.com is a good site to run a check.
I am thinking about increasing my RAM from 1 GB to 2 GB. Today I did the "Crucial " test and it told me I had 4 Gbs!Originally posted by coupekid View Post
I started with half a Gb and added another half Gb from Cruicial about 3 years ago, so do a double check if you use Crucial's download software!
I have also used Belarc Advisor (free download)
as this is what is says:
1024 Megabytes Installed Memory
Slot 'A0' has 128 MB
Slot 'A1' has 4096 MB
Slot 'A2' is Empty
Slot 'A3' is Empty
I can't really understand it as you can see initially it says
and then it says:
I do only have the 1 Gb though.
Can anyone through any light on this misinformation?
Can't help on the Crucial test. My test result is exactly what I thought. I have an Intel Core Duo and it runs most things very fast. I think the RAM issue is a problem when I run Lightroom and PSE5 simultaneously. I use a 20" CRT monitor from Sony. I won't change to LCD until I have to because I like the high resolution. Up to 1600 x 1200. An LCD of this resolution is very expensive.
I may be upgrading Julia's laptop as she is finding her 17" single core machine too slow and too heavy
This caught my eye:
http://www5.pc.ibm.com/uk/products.nsf/$wwwPartNumLookup/_TY2B4UK?OpenDocument
Get minimum 1440x900 screen res, 7200 RPM SATA hard drive and 2GB RAM.
Hello BenOriginally posted by coupekid View Post
It is a basic Dimension 2400 with no upgrades. The ram is very low and needs upgrading.
I looked at the 9200 and the spec is way above mine. If I can get away with a ram upgrade only I will go that way. It's the cheapest upgrade and won't do the machine any harm anyway
Hi Tom,Originally posted by Tom View PostHello Ben
What spec CPU do you currently have?
Memory and hard disk upgrades may be a good solution, but this depends on the CPU.
