I wasn't able to get over to the test studio this afternoon after all, so instead I did a quick and simple noise comparison test using the Olympus E-400 (with the new 14-42 kit lens) which arrived today, an Olympus E-330 (with 14-54 lens) and a Sony Alpha A100 (18-70 kit lens).
The pictures were taken in a 12 foot square room lit with three ceiling-mounted 60W household (tungsten) lights with the reflectors upwards facing. All the cameras were tripod mounted, set to aperture priority auto exposure mode, with the aperture set to f/7.1 and segmented metering mode. At ISO 100, the two Olympus cameras agreed the shutter speed should be 1 second and the Sony reckoned on 0.8 seconds. Auto white balance was used and JPEG recording was set to best quality. The Sony has a wider aspect ratio frame but all three were aligned to the same horizontal points. The E-330 is only 7.5 megapixels compared to the 10 megapixels of the other two.
Below you can compare the results of a 250x250 pixel crop from a near-central area of the frame. What you see is a section of a Gretag Macbeth ColorChecker SG colour test target perched on a mantlepiece in the room.
The Olympus E-330 (left), up to now, has represented the best Olympus has been able to offer concerning resolution versus noise, being decidedly superior to the 8MP E-500. I wasn't optimistic that the one third increase in pixel count would do the noise characteristics any good, but I have to say I'm pleasantly surprised with what I see here. The crops look clean and noise is, if anything, a good match for the E-330 at the higher sensitivities, with the benefit of superior resolving ability. The E-400 also compares favourably with the larger-sensored Sony Alpha A100. There is obvious fringeing in the Sony crops, something neither Olympus lens suffers from.
Comments here on the forum most welcome!
