Testing upload of pic
  • Testing upload of pic
    I have had trouble trying to upload a pic to Galleries so thi is just to see if it will upload here.
    Re: Testing upload of pic
    Wow - is he carrying giant popadoms?
    PS Is the gallery working for you now?
      Thanks Ian - I did not get time to ask him how big they were or how much, it was a quick grab shot as we were being urged to get back on the coach.
      In answer to you second question - after succeding with this upload I then went back and uploaded the same picture to an album named India05 which I had created earlier and was successful this time. The only difference from the attempts which failed was that I had reduced the size of the picture from about 1200KB to 250KB and shortened the name of the file.
      I need to do some more tests to find what the limitations are.?? Was it the size of the file which caused the trouble Ian ??
        Hi Dennis I had a suspicion it was the file size causing the problem. I think you will find the file size limit is 250kb. I find if you keep the file within the range of 800-1000 pixels there is no problem keeping the size within 250kb
          Hi Stephen
          Thanks for reply with info. I thought that might be the case, but what threw me was that the error mesage kept implying it was not a valid 'jpg'.
            Ah, yes - the file size. The individual file size limits should be the same on the gallery as the forum. You need to resize your images for on-screen display before uploading. 250K is reasonably generous for JPEG sizes that can be viewed comfortably on-screen and often you will only need quite a bit less.
            See: http://dpnow.com/forum2/showthread.php?t=59 for Pol's post explaining how to find the image types and sizes allowed.
              Hi Ian - Many thanks for info. Actually I had already sussed out these size conditions when I successfully uploaded the same picture that I posted to the general forum to the member gallery 'India05' that I had previously created. I now have no need to carry out further tests.
