Image Signature
  • Image Signature
    Hi, if anybody knows how to add a signature to an image in cs2, it would be much appreciated, or if this cant be done then a program that will do it easily, and for free.
    I have found the watermark feature in cs2 but from what i can tell requires registration and payment.
    cheers
    Ash.
    Re: Image Signature
    cheers
    Ash.
    Ash, the feature you refer to doesn't really do what you want. What you need is the text tool. Type onto your image whatever you want. This causes a text layer, which you can adjust in the layers palette for opacity etc. Or if you click on the icon in the layers palette for Add a layer style there are all sorts of effects. You can move the text around to position it, then flatten layers before saving. Thats it in a nutshell. It is also possible to create a separate PSD file with your sig ready prepared which you can drag onto your image, this saves time if you do it regularly.
      Re: Image Signature
      Thankyou so much, I ow you pint
        Re: Image Signature
        or you could do this by creating a 'brush'. once created, you simply call up the brush tool and stamp your image anywhere you like.
          Re: Image Signature
          Then record what your doing as an action.........it will save messing about next time...and the time after that....and after that.......
            Re: Image Signature
            sorry chaps im still not getting how I save just the little bit of text that I type onto the image, to recall later to put on another image.
            If you just go through it step by step you can have one of my choc chip cookie's I have just opened:b best be quick though there going fast!!
              Re: Image Signature
              Ok here ya go...
              File > New create a file roughly 250x50 pixels, I leave the background transparent but white will do.
              Type your sig + copyright logo (Alt + 0169 on num keypad)
              Position within the frame till you are happy, and apply any blending options using the icon at bottom of layers palette. You may need to alter opacity and fill also
              Finally save as a PSD file which will retain the text layer.
              Everytime you want to apply it, (this size is for a web image and may beed alteration) just use the Move tool to drag the text layer across to your image and reposition. Sorted
              This is only a basic method, there are variations. The Brush method is OK but more problematical in my opinion
                Re: Image Signature
                fantastico , I couldn't get the copyright logo to work though, it does'nt seem to do anything, do you mean hold alt, then type in the number, or press all the buttons at the same time?
                Anyway that was just a bonus Im not to bothered if I cant get that working.
                thanks for your help
                Ash.
                  Re: Image Signature
                  Ash.
                  Keep your finger on Alt then type the number using the numerical keypad. Doesn't work with all fonts though
                    Re: Image Signature
                    Ok here ya go...
                    Alternatively.......
                    Open a new Photo
                    Unlock layer
                    Click on 'new set' (call it Signitures for example)
                    Click on 'new action' (call it Ash Signiture for example)
                    Click Record
                    Click stop.
                    Now every time you bring in a photograph, you can just click on the action....then change the font, size and position which suites each picture.
                    (my way is easier )
