Help
  • Help
    not recommended 1280x1024 optimum and nothing will display so I have no idea how the repair is going. I beleive it to have locked.
    Help please
    Re: Help
    Help please
    If any one has read this and can help with some advice please reply, this is my work computer and I nead to get it started very urgently.
      Re: Help
      Are you able to try a display card driver update?
      If you boot up in safe mode (can you do this) what happens?
        Re: Help
        Hi Patrick, clutching at straws here, but could it be the graphics card thats playing up, maybe needs replacing
          Re: Help
          Hi Ian
          Thanks for replying
          I haven't tried safe mode, I can't find a way to do so now as the OS is half way through the repair but would appear to be locking up but with no screen I don't know where.
          I am trying to create a bootable external H/D with a restored setup to run on my laptop, which hopefully with the correct BIOS settings will boot from the external drive. if this works I may stick with it as it would keep work and leisure apart but using one machine and without using the smaller capacity laptop H/D.
          It doing the restore now we shall see.
            Re: Help
            If that the case its a shared graphics and no provision on this machine for an independent card.
            It does show the opening screens as fare as the first one goes with the bit at the bottom that runs along, then tells me setup is resuming and the screen closes with the message I have quoted.
            Thanks Stephen anything is worth trying
              Re: Help
              Hate to say this Patrick but if you backed -up the system after the problem started you have also backed-up the problem! Your best hope is system restore if you can get to it, the earliest restore point possible.
              If you can get into safe mode I would recommend running a system file check using sfc /scannow because it looks as if you have some corrupted XP files.
                Re: Help
                  Re: Help
                  Those that replied to my screams for help, may be interested to know after a great deal of work trial and error, I have retrieved my data.
                  I had made a Powerquest backup but that didn't work properly nor did the saved file & settings using Windows.
                  Anyway through Powerquests browser function I was able to retrieve most date a step by step. The rest was retrieved because I had also made a copy
                  of the drive. Belt and braces pays in the end.
                  The amazing thing despite all my precautions I still found myself in this position.
                  Looking forward now to the new laptop.
                    Re: Help
                    Hi Patrick,
                    I'm sorry that you were having so many problems and I'm very pleased that you have now resolved them but your difficulties have highlighted a very common problem: It is not enough to make backups, you also need to make sure you can restore them. This may seem obvious but I know of several companies that had very strict backup procedures in place only to find that their backup tapes were actually unreadable when the crunch time came.
                    Vernon
                      Re: Help
                      Originally posted by vlarcombe View Post
                      Hi Patrick,
                      Vernon
                      Exactly, but how can we check our backups will restore we only find out when they don't work, and its too late then.
                        Re: Help
                        A fair point.
                        In the absence of a second machine I "sample" the back up, restoring 1 or 2 files and checking the backup logs to make sure there are no errors or warnings. I have to admit that I was very nearly caught out myself last year having changed to backing up just my data, knowing that I can re-install everything else. What I forgot to backup was my mail files where all my registration numbers etc. were stored! (I do have them all on paper "safe" but finding them in a searchable mail-box is a lot easier than finding them in my paper filing system ). Luckily I had a mother board failure and not a hard disk failure so I could quite recover what I was missing.
                        Vernon.
