Mega Pentax shaping up well
  • Mega Pentax shaping up well
    Only taken a few test shots since getting the HUGE Pentax 500mm f4.5. It's a real monster so I haven't really taken it out yet and as it produces much better results stopped well down I don't often get the chance to use it on a bright day. I decided I had to get to grips with it so today, out of the bedroom window I took some shots of a Rooks nest in the tree tops around 160 metres away with the added encumbrance of adding on the x1.4 converter. i have to do some more work but this 50% crop seems to give more promise than I had originally found, you can just see the female's head above the nest:
    E-M5 plus Pentax 500mm f4.5 and 1.4x (1400mm EFL) - Manual Focus
    Jpeg ppd in LR
    David
    Canon 7DII, Sigma 150-600mm Sport, Sigma 18-300mm, Sigma 8-16mm, National Geographic Expedition Carbon.
    Re: Mega Pentax shaping up well
    Well, maybe I am expecting too much but even in this web-resolution result it's lacking a certain crispness?
      I imagine it was windy so there'd be a lot of movement which would affect crispness., but I'm not overwhelmed by the colours. The leaves seem to be slightly too yellow and the nest too light and orangey though the could be dealt with corrected in software.
      Nice to see the bird's head poking up above the nest though!
        Thanks for the comments. Yes it was blowing a hooley and there was a fair degree of heat haze - an unavoidable problem taking photographs over a long distance on a warm sunny day. This is another taken around the same time, difficult to focus owing to the shimmer and the whole tree moving a lot. I've worked on the colours a bit, I'm not used to the jpeg effect - must go back to RAW.
        David
        PS - Raining cats and dogs now, time to open the wine!
          Originally posted by David Morison View Post
          Thanks for the comments. Yes it was blowing a hooley and there was a fair degree of heat haze - an unavaoidable problem taking photographs over a long distance on a warm sunny day. This is another taken around the same time, difficult to focus owing to the shimmer and the whole tree moving a lot. I've worked on the colours a bit, I'm not used to the jpeg effect - must go back to RAW.
          David
          Yay, that's pretty good. Nice to be able to see some good detail of the bird from such a distance. The colours are also much better and more true.
          I'm also interested to note the flowers are hanging on the Sycamore! Ours only came into leaf maybe 7-10 days ago but no yellow flowers showing yet (or maybe I need to look at it more closely through the binos or a long lens.
          Enjoy the wine. I'm about to indulge in fish 'n chips with pineapple juice.
            Hi David, You managed to get good detail over that distance and your shutter was fully open even better using raw. John.
              It may appear that way but it is a 30+ year old lens with a 1.4x converter and if you compare an identical crop from a shot taken of the second nest with the M4/3 75-300mm (less than half the EFL) using AF you can see the advantage it gives me:
              Looking at a larger crop to give roughly around the same magnification with the m4/3 lens you can see just how much more detail the Pentax gives:
              Definitely worth the £240 it cost me but the m75-300mm is a little more portable though!
              David
